Posted July 14, 201312 yr hey guys ive been studying wiring diagram on the 125 x, trying to figure out the sidestand switch now as it might be reason getting no spark, anyway i have 2 black and white wires 1 for sidestand other for clutch, only thing is its showing me on diagram to connect them to anti-theft alarm which is an optional thing by the looks of it, i dont have one with my loom, anyone any ideas where it would connect too then?
July 14, 201312 yr Author Black/ whites , usually to CDI. Or ignition,, there the grounds,, well they cant go to cdi, going by diagram they are meant for an anti-theft yoke but the main red wire is not wired for that so ill assume didnt have one to begin with really stumped now, dont know how they would tie in with ignition though.......
July 15, 201312 yr Moderator Clutch and side stand cut out switches are normally just an earth to stop the spark. The same as an engine kill switch. If the wire(s) are disconnected from the switches they won't kill the spark.
July 15, 201312 yr Author Clutch and side stand cut out switches are normally just an earth to stop the spark. The same as an engine kill switch. If the wire(s) are disconnected from the switches they won't kill the spark. this is what i had thought my self actually thanks
