Posted June 25, 201312 yr My '76 DT125 turn signals stop working at high RPMs. They come back on as the RPMs come down. It also stops running after a few minutes at high RPMs. It acts as if the key was turned off. It will start right back up. Any suggestions?
June 28, 201312 yr Moderator Cynic bang to the rescue cleaning away those pesky posts.... Might want to check you output voltage and if the diode under the tank is breaking down.
