Hydraulic clutch..
Cynic
This post is 4189 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Just a quick question. Trying to narrow my search down a little.
Looking for a clutch master cyl that will match the fr brake on the Tdr. Something 88 to 90.
Google is too vague just gives more search engines and options. So thought id try old fasioned experience.
You all know the look. Black with built in square resivoir and black lever.
Any ideas welcome...
I know BANSHEE do a clutch conversion kit but that is on the engine side not the handlebar type, not sure about it otherwise, if you find out anything please let me know as it would make any bike easier to handle if you don't have to manhandle a lever and cable. :jossun:
There are kits on the market that are stand alone slave cylinders with cable fittings. You can buy their master cyl or use your own. Thats why i want a period match for the tdr. Then the slave can go under the tank and nothing looks out of place. Then i can ride it properly again.
