June 5, 201312 yr Hi. New to the forum and have an rxs 100 that I wish to restore. I used this on a daily basis for two years and over the last two weeks it has been difficult to get Into a gear. I could change up and down the box but without the return spring doing its job. It is now stuck in first gear and will not come out of gear at all... Is this spring broken ?... And is it grief to fix??. I am fairly ok with the technical stuff but useless at diagnosis.any answers would be appreciated. Many thanks
June 5, 201312 yr Author The clutch lever is operational. The foot lever is not... I can start and run no problem and go to shops etc... As long as its in first gear !!. I have yet to make a start and have the case off and a mate says its an easy job... However... It's only easy of you know what the diagnosis is.
June 5, 201312 yr Only way to find out is take it apart, no one else can tell you what's wrong with it without looking at it! Best I can offer really, once you have it stripped down and know what is wrong or broke then we can help as to a fix but not till then I'm afraid.
June 5, 201312 yr Check all the stupid stuff first, such as oil level, fouling, rust, lubrication, etc.
June 5, 201312 yr Moderator I am with Ttaskie on this one. My questions were about checking that the gear lever wasn't flapping (dodgy splines or bolt) and that the engine hadn't seized and locked the gearbox. I would next remove the detent bolt (stopper cam) be careful not to lose any spring or plunger and then try moving the lever. Next I would have the cover off to see if anything looks jammed.
June 5, 201312 yr Moderator whatever it is it wont be too difficult. is the lever springing back to a central posn?
