May 20, 201312 yr Last night it (the 83 XJ900) finally started . After sitting for about 10 yrs, it is rough but ran for about 5 minutes while Playing with the idle. Got a miss or two and got spark shooting out of the exhaust which is way to loud (guessing some rust etc). Choke cable was seized solid so thats off for now. Piece by piece....
May 21, 201312 yr Author Haven't figured how to post pics yet but did get it into my profile and into the vehicle section let me know if you can see it. Still have more to do yet to get her running decent though. It's in the garage section as well
May 21, 201312 yr Author Question do you guys run a second inline fuel filter or just the one off the valve ?
May 26, 201312 yr Author Well worked on the bike this morning, got the bike running but now she's dumping fuel from all 4 carbs down the overflow tubes. Since the bike has been sitting for a looonngg time guessing float or needle seats are stuck. Any other spots I should check . Man don't want to take the carbs back off........... Afterr doing MORE searching realized the 2 5/16 "vent" lines where plugged into each other, hence no venting, which would be causing the backpressure in the carbs I'm guessing. Going to pull one off today and see if thats the issue, so much better the removing carbs.....who makes vent lines that big ????
May 26, 201312 yr seca If you have photobucket, all you have to do is: Load pic onto PB click on gear icon (top right of pic) click 'get links' double click on direct link On your post click on the 'image icon' just below and to the left of the smiley icon paste your link onto that and tada
May 27, 201312 yr Author Thanks Jimmy and thanks for posting it, also found out last night that the carbs on it are not the original one..now I have to find out what they are from. getting myself in deeper lol
May 31, 201312 yr Pleased to hear that it is running, just the usual OLD BIKE problems to sort out which means sorting out other peoples horrible fixes or bodges, just keep plugging away once it's running it's all down hill.
