May 17, 201312 yr i have a 1982 sr125 and im stuck on which headlight bulb it takes, its not h4 like the new ones, its some kind of 3 prong fitting with bayonet cap, dont suppose anybody knows which bulb fits?
May 17, 201312 yr http://www.ebay.co.uk/itm/Yamaha-SR-125-10F-1996-2002-Neolux-Hi-Low-Beam-Bulb-Headlight-Lamps-/330862477530?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d08f0c0da sounds like what you might be describing? but it says for 96-02. have a look at the specifications, they might help you figure out what bulb you need? sorry i couldn't be more help
May 17, 201312 yr ahh just noticed you said its not H4, hmmm. In that case i don't have a fucking clue i'm afraid
May 18, 201312 yr Author got no idea about any from that link mate would have to be photos of the bottom of the bulb really, and its 12 volt airhead, heres a crappy small pic off google of the bulb in the holder http://thumbs3.ebaystatic.com/d/l225/m/m1y2Je3FfQsyOHwJkx7PhIg.jpg and this is the pic of the exact one i bought http://i.ebayimg.com/t/Yamaha-SR125-Head-Lamp-Bulb-Holder-/00/s/MTIwMFgxNjAw/$T2eC16NHJG8E9nyfmYkKBQ8DlN7s4w~~60_35.JPG ill take a proper pic in a bit showing the inside / fitting
May 18, 201312 yr I think Benedictine on here has had to change his bulb recently and he's got an early 90's SR. I've not had to change that one yet!
May 21, 201312 yr Moderator LINKY1 - I don't think it is this type. But just in case. LINKY2 - I think it is one of these.
May 21, 201312 yr Moderator They come in both 6v and 12v so make sure you got the right ones. A simpler fix is to get a patten headlight that takes a H4 bub. These are available in 6v and 12v too. All you need to do is get the right size and be able to do a little, simple, wiring.
May 21, 201312 yr Author ah i know practically every tungsten bulb comes 6v or 12v just want the standard bulb for the mot then im gonna put a new holder and h4 hid in there lol, but the 3 prong bayonet fitting i hadnt bought a bulb for in past so didnt know which bulb itd be
May 22, 201312 yr Author sorted, fits, problem solved... OLD SHAPE SR125 BULB FOR FUTURE!!! http://www.ebay.co.uk/itm/140653746993?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
May 22, 201312 yr Author ahh yes, thanks dt... wasnt being rude was just in a rush to post it up that its the right one.. seriously, ur a life saver, thankyou next project, getting the bleeding indicators working think i need a new relay but wanna get them on at least constant first, left side doesnt seem to be friendly but right works, or at least stays on solid
