Posted May 11, 201312 yr About a year ago my fuel tank sprung some leaks. since then I bought a new tank off e,bay for a fraction of the price, but I have repaired the original tank externally. What i am trying to do now is internally seal the original tank. I seem to have two options, either POR 15. or Kreem. This is where I need advice, which one? When I do get the right one, how do I apply it, just pour it in and swirl it about?
May 11, 201312 yr Never used these Mike but I suppose it tells you how to use it on the tin! I think you must be right about pouring it in and swirling it about as unless you have a very strange paint brush there is no other way I can think of it working, I wonder if it should just coat the bottom half of the tank as that is usually where the holes appear? Someone will know on here, be nice to find out myself what you have to do.
May 11, 201312 yr mike Iv'e seen some video on youtube showing how to do it, as I remember you make plastic template to cover fuel tap & bolt it on using the bolts from fuel tap,plug up any other hole's like breather pipe, mix sealant with hardener, poor in & swirl it round make sure the sealant you use is ethanol resistant
May 11, 201312 yr Moderator These are the people i used...http://www.tankcareproducts.co.uk/ Seems to work too. My tank has been done 3 years now.
May 12, 201312 yr Author Cheers all, I really do appreciate the input. Will look into depth Cynic's link.
May 12, 201312 yr I used kreem about 2 years ago to seal a friends tl1000s tank,very easy to use. 1 clean all old rust out ,1 lb of drywall screws in the tank and shaken on a bbq rotisery for 2 hrs worked great 2 water rinse,dry and wash out with the provided acid wash 3 mix sealer and hardner and coat inside of tank by rotating,working time was quite long 1/2 hr or more so it was easy to get the whole tank sealed.The stuff is quite thick and not runny. I only blocked off the petcok hole with a piece of gaffer tape,2 old bolts to fill the thread holes and removed them before the sealer fully hardened.Job done for 60 the shops wanted 200.Had enough left over to seal a small dirt bike size tank about 1/3 of the kit Ps I only sealed to the top underside of the filler neck leaving the cap sealing area uncoated
