May 11, 201313 yr Ive put the power valve on the 170 barrel and when i tighten the outer casing and tighten it the valve wont move atall untill i untighten the 2 bolts any ideas?
May 11, 201313 yr Moderator Could it be something you've done wrong or set up wrong...rather than a manutacturing fault?
May 11, 201313 yr Author could be ive never set one up before on these bikes ive followed the instructions that came with it and i took my old one apart but ill do it again tomorrow double check
May 11, 201313 yr Author yeah i think ive put it inside the barrel wrong the servo tells it to do a cleaning cycle when i switch my ignition on so im guessing i flip it and go from there
May 12, 201313 yr Author power valves working perfect and is set up correctly just need to wait for my bearings and put her all back together
