May 10, 201312 yr Hi, I've recently bought a very tired '86 RD350 N1 with a view to restoring it. The engine didn't turn over so I've started with that first. I've stripped the engine to find that the crankshaft has a rusty big end. I've spoken to a few engineering firms in the UK and they have given me quotes of between £300 - £390 to rebuild it. The thing is, I found new cranks for sale at Yambits for the same money. Does anyone have any experience with Yambits cranks, are they OK? Apparently they are brand new, not reconditioned, but the price just seems to good (or the rebuild prices are too high ). Thanks. _________ http://rd350nrebuild.wordpress.com/
May 10, 201312 yr Here is a link to the RZ forum discussing the Yambits Cranks http://www.rzrd500.com/phpBB3/viewtopic.php?f=15&t=9770 Tony
May 10, 201312 yr Bloody hell did they drive it to the Channel Islands? Looks like it was run underwater. That Yamabits crank looks ok and seemed to have all the parts that you need, give it a try the worst that can happen is you have to do it again! P.S might be an idea to do a PROPER INTRO rickster in the "new members" section, welcome to the YOC.
May 10, 201312 yr Moderator contact Norbo he reconditions cranks http://homepage.ntlworld.com/ultimatelccrazy/
May 11, 201312 yr Author Bloody hell did they drive it to the Channel Islands? Looks like it was run underwater. That Yamabits crank looks ok and seemed to have all the parts that you need, give it a try the worst that can happen is you have to do it again! P.S might be an idea to do a PROPER INTRO rickster in the "new members" section, welcome to the YOC. :-) you could be right, it could have been underwater. I think though the barrel gasket gave up and coolant dripped down onto the bearing. The bike hasn't run for years so it's had plenty of time to fester. The left-hand side of the crank is perfect. I'll probably go with the Yambits crank, the rest of the engine looks good so it will be worth it. I'll nip into the "new members" section and introduce myself. Thanks guys for your replies.
