Got all the stuff :P.
What temperature do you let the tin heat up to? It's very hard to find any information about this method of waxing your chain.
Also, about cleaning your chain prior to waxing, will B&Q Bartoline Premium Paraffin do the job? I came across a thread that mentioned using paraffin that's for lamps, heaters and burners is not recommended on chains.
//Edit
Just wing'd it. That B&Q paraffin worked pretty well. This Putoline Chain Wax does a pretty good job, glad I gave it a try! Thanks for the suggestion :P.
  • Replies 40
  • Views 7.5k
