XT250 HEADLIGHT WIRING
can anyone help got a 1981 XT250 cant get head light to work. need a wiring diagram if anybody knows where I can get hold of one. cheers
also cant remember if the H/LGHT only works with engine running.
Mr lubber lubber.
Love the name but you really need to say "hello" in the newbies section my friend. a little about you helps a lot. Generally there is a better response form members who do this.
Yes " it be 6 volt system, needs engine for headlight,, best wiring diagrams are , Kojacat ,,, coloured and a baby can read them,, :yeah:
Seem to remember the XT250 was only a 6 volt system so lights only worked with engine running. Does the ignition switch have just an on/off position or is there a position you turn to for the lights or is there a on/off switch on the LH handlebar switch.
the head lamp is fed with AC direct from the generator.
