Clutch washer plates
I bought a set of new clutch plates for my DT 80, and I tried to do the change yesterday. But when I remove the old clutch plates, in the basket there was 5 clutch plates and 3 washer plates (between two clutch plates one washer plate is missing) . So I was wondering is it ok to leave it like that, or should I look for washer plate?
Worth to be mentioned: one of the old plate (where waser plate was missing), was broken. I`ll put an image when I go home.
Not familiar with that bike, but if it has 5 friction plates then it should have 4 plain plates
You can see the motorcycle
Basket and clutch plates are the same with DT 125
