This post is 4316 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi can someone hlp I have yammy yb100 the break light will not work the normal light works but no break light when foot pedal down can you shed any light cheers
Hi gpm" you need a multi meter. to check A - if thers power at light socket, and B continuity of wires etc, Also take this to workshop ,as this is for new members,section, as it says at top of page,
You don't mean "brake" light by any chance do you??
no it's broken so it's break :eusa_whistle:
Change the bulb. They are called "stop & tail". 2 lights in one bulb. That is normally the problem.
Hello, by the way!
