February 2, 201313 yr Hi can someone hlp I have yammy yb100 the break light will not work the normal light works but no break light when foot pedal down can you shed any light cheers
February 2, 201313 yr Hi gpm" you need a multi meter. to check A - if thers power at light socket, and B continuity of wires etc, Also take this to workshop ,as this is for new members,section, as it says at top of page,
February 2, 201313 yr Hi can someone hlp I have yammy yb100 the break light will not work the normal light works but no break light when foot pedal down can you shed any light cheers You don't mean "brake" light by any chance do you??
February 3, 201313 yr Moderator Change the bulb. They are called "stop & tail". 2 lights in one bulb. That is normally the problem. Hello, by the way!
February 3, 201313 yr Moderator yep check the bulb first, you can usually see if it's a broken filament in there
