Break light
Hi can someone hlp I have yammy yb100 the break light will not work the normal light works but no break light when foot pedal down can you shed any light cheers
Hi gpm" you need a multi meter. to check A - if thers power at light socket, and B continuity of wires etc, Also take this to workshop ,as this is for new members,section, as it says at top of page,
You don't mean "brake" light by any chance do you??
Change the bulb. They are called "stop & tail". 2 lights in one bulb. That is normally the problem.
Hello, by the way!
