February 1, 201313 yr hi need help i have a sachs zx 125 2 stroke ive been told it is a yamaha dt engine my question is when it rains the bike will cut out then start cut out start etc i have changed the coil plug lead and plug plus cap a friend of mine said it could be the magneto (seams to be ok in dry weather) can any one help me out or give me advice please thanks antony
February 3, 201313 yr Hi, if you post an intro about yourself in the new members section, you will get a better response.
February 3, 201313 yr like grouch syas introduce yourself first... have a look at the magneto see what condition it is in, if water is getting in there you will find signs of corrosion could just need a good clean up/light dust with sand paper and some instant gasket around the cover. you will never know until you crack the case off ken
February 3, 201313 yr Moderator hi need help i have a sachs zx 125 2 stroke ive been told it is a yamaha dt engine my question is when it rains the bike will cut out then start cut out start etc i have changed the coil plug lead and plug plus cap a friend of mine said it could be the magneto (seams to be ok in dry weather) can any one help me out or give me advice please thanks antony Run that by me again Ant?
February 4, 201312 yr My money is on the coil lead tracking across to earth , is there a rubber boot both on the coil side and the plug cap. Use NGK or Champion caps but just add some silicone sealer into the lead ot eliminate any chance of water ingress, Also worth checking the positive lead to the coil and check the earth points at the coil, eliminate this area and work you way back to the CDI unit and the generator coil. TTB
February 12, 201312 yr Sorry I'd have to disagree, oilbased products should not be put anywhere near the ignition. It may be a bodge that'll get you home but it adds to the problems by providing a source of material that readily breaks down to form a coductive film. We get sent ignition systems for testing, those covered in WD40 or insulation tape (holds water and muck) tend to prove to be completely scrap needing all the parts replacing. Those left dry can often be saved by just a new lead or coil.
February 12, 201312 yr have you checked the air filter? mate of mine has a cg125 and it was running like crap in the rain and for a couple of days after the rain. we checked through it and found that the air filter was soaked. did a bit of lookng over and figured out how it was getting wet. sorted that issue and dried the filter and all is good....
