This post is 4351 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Recently I upgraded my bulbs and ever since the sidelight has stopped working and now my bike will only start when it is on high beam. What could be causing this?
I knew I should of just left the lights as they were and not interfered, it has caused loads of problems.
Thanks
is the controls for the lights on the same as the electric start button?
have you tried starting with no bulbs in? then select high beam see if its the controls
ken
yeah i'm thinking you overloaded and possibly melted some wiring? It's goint to be a tough one to solve
FFs, that's all I need
Hey Grouch a couple of ??
1 does the bike turn over on low beam? but not start
2 If you pull in the clutch in netural will the bike turn over on low beam?
3 By side light do you mean the signals and is it just the front or front and rear? And do the signal work?
4 Can you start the bike in gear with the clutch pulled in?
By side lights I think he means the small bulb in headlight next to main bulb!!
I'm thinking, with your own self confessed inexperience in working on bikes, is that you have mixed up / disconnected / disturbed some wiring in the headlamp. Get a wiring diagram take the light off and have a look
