January 23, 201313 yr Hi my name is Fraser and I'm from Lincoln, I have a Yamaha xt 125 57 plate, I tried starting it yesterday and nothing happened when I turned the key (apart from unlock the wheel ) and I think there has got water into the ignition barrel, I have checked the main fuse and that looks fine, is there any other fuses I could check? If the is nothing I can do I would like to know if anyone can tell me how to bypass the ignition barrel? please help its hard work on a push bike many thanks Fraser
January 23, 201313 yr Moderator Hi and welcome to the forum. Did any lights come on (neutral etc). Check the battery hasn't died due to the cold.
January 23, 201313 yr Author HI thanks for the reply, No lights at all battery is fine I've checked it. I have a kick start and can put a wire if the starter solenoid to turn it over. Any other comments would be great, thanks. Fraser
January 23, 201313 yr Hi fraser does the bike bump start or kick start? Do you have spark when kicking the bike?
January 23, 201313 yr Moderator Achh Fraser please dont clutter up the intro thread with bike problems, post it somewhere more suitable this section is for hello's so hello greetings and
