Posted December 21, 201212 yr me again.. decided to change the reed block on my rxs. already had a spare and fiber reeds installed on that. so i went about doing that. I noticed that most of the bolt heads were 10mm but 1 was 11mm they were all sorts of diferent lengths 1 was barley long enough to gain purchace on to the actuall cylinder.. so im wondering what bolts should i get for it. il probably get them from yambits if they have them. but i need to know which.
December 21, 201212 yr Moderator you could do worse than http://www.mrmegapack.co.uk/ I am not sure what you want but Andy may know
December 21, 201212 yr Not familiar with the bike, but some basic rules: Make sure that you fit the same bolt that came out of the hole. Make a cardboard template/sketch and shove the bolts into the holes so that you've got a map Its the diameter of a bolt/screw that governs what you order. A bolt with a 10mm hex head across flats will be 6mm diameter by whatever the length is when measured from the underneath of the bolt head ie 6 x 30 is 6mm diameter by 30mm long Countersunk screws/bolts, length is the complete length of the bolt/screw from top to bottom 8mm across flats is 5mm dia 10mm across flats is 6mm diameter 13mm across flats is 8mm diameter 17mm across flats is 10mm diameter 19mm across flats is 12mm diameter Having said that, you might occasionally come across some oddball sizes, most important is that you get the diameter and length right For the bolt that you say isn't long enough, measure the depth of the hole, add on the thickness of the part that is clamped between the bolt and the hole, then take 3mm of that figure.
December 21, 201212 yr Moderator 8mm across flats is 5mm dia 10mm across flats is 6mm diameter 13mm across flats is 8mm diameter or 12 mm across flats on jap bikes 17mm across flats is 10mm diameter or14 mm across flats on jap bikes 19mm across flats is 12mm diameter
December 21, 201212 yr Moderator The age ol stickler... To a mechanic a 13mm head is a 13mm bolt. To an engineer the same bolt is an m8. When i did the dt i bought a mixed pack from mr fastner. 4,6,8 and ten mm allen headed Semi stainless bolts with nuts. All metric fine. As i took out a manky one i swapped like for like.
December 21, 201212 yr Author I dont think these things i pulled out are original ones... They seems to be a mish match of any given bolt that some one had at hand that seemed to do the job at the time.. thats why i thought id come check what really should be in there. These bolts may "work" but they arent right.. and i dont want to replace them with a "bolt pick n mix assortment" I have a feeling that they may be letting air in passed the reedblock causing some of the issues the bike has.
December 21, 201212 yr Author nope.. I do have a manual boxed up, may crack it out of the box but i doubt its going to telol me the size of the bolts.
December 21, 201212 yr Author rx says 9750N0652500 BOLT HEX WITH WASHER 4 000202107 000202107X00 975070652500 i assume they are the same.. and aparantly they should all be the same length. can any 1 confirm that these will work on a rxs? and that they should be 4 of the same bolts.. and if possible can some one translate these parts in to bolt sizes for me? only 1 of the 4 that came off the bike had a washer. so i think that 1 was original. i may be able to use that to source others. but id really like to order them.. i did find one place with them.. 64p for the parts then £8 postage.. seemed a stupid ammount for postage so i passed. http://img145.imageshack.us/img145/9568/rxpl.jpg its item "4" in the list
December 23, 201212 yr Author can any one confirm the above? and hopefully translate some of those numbers i to a bolt that i can use? the washer isnt a worry i can hust get the callipers on to one thats is actually on the bike. but id like to get these bolts orderd asap... i have new engine cover bolts on the way decided to go for allen type button, stainless ones, (because i doubt il be re using the rusty ones on there now. but i really need these bolts for the reed block. i threw it backtogether looseley. and it revs better with the fyber reeds, but it still has no reall power and if i losen some of the bolts the power issue gets worse, so i really think its sucking some air passed the reedvalve,. i will be uisng some instant gasket aswell as an official gasket to make sure that there is no issues at all around the area, but i really need the correct bolts.
December 23, 201212 yr Moderator http://www.yamahascooterspares.co.uk/spares/partImage.asp?GPN=975070652500&uID=0
December 23, 201212 yr Author i found them but £6.50 postage for 4 bolts is not something im willing to spend. 4 bolts are £0.80 total cost comes out to £ 8.76 i want the bolt size's so i can order them some where that is not extortionate on postage . i can send two 4kg xboxes (8Kg total) next day delivery for that kind of money. 4 bolts should be like £0.90 max postage, maybe add on £1.20 for a padded envelope which are only £0.99 but honestly im not paying £8.76 for £0.80 worth of bolts..
December 23, 201212 yr Moderator Crikey. They are 6mm metric fine with 10mm heads. 30mm or therabouts in length. Prob get them from screwfix this afternoon if your quick.
December 23, 201212 yr Author great thanx! i think thats a m6 then il double check that i havent done any engeneering since about 1997 Ah ha.. £1.20 all in ! take that postage costs!
December 23, 201212 yr Moderator I dont think they are metric fine, they arent on mine and theres no reason they should be...and they should be 25mm long
December 23, 201212 yr Author wait 25 or 30mm? I was still perusing diferent type heads i could use and debating betwen using allen buttons or proper 10mm heads. (i think the 10mm hex heads would be easiest to use given where it is.) So this would be a great time to figure out the 5mm diference.. If its not known i think id go for the 25mm as atleast then i can be sure that the dumb thing is on tight. but if it is known either way id like to get the correct length.. having said that even if i order them today they wont be here till after christmas so i guess it not a HUGE rush. also how are you geting the diamiter and length info, because i cant figure it out from the numbers in the parts list.
December 23, 201212 yr Cant help with the pitch, but if in doubt, get the longer ones, you can always cut 5mm off with your hacksaw. The more that you can fill of the threaded hole the better, but dont bottom out on the hole
December 23, 201212 yr Moderator rx says 9750N0652500 BOLT HEX WITH WASHER 4 000202107 000202107X00 975070652500 i assume they are the same.. and aparantly they should all be the same length. can any 1 confirm that these will work on a rxs? and that they should be 4 of the same bolts.. and if possible can some one translate these parts in to bolt sizes for me? only 1 of the 4 that came off the bike had a washer. so i think that 1 was original. i may be able to use that to source others. but id really like to order them.. i did find one place with them.. 64p for the parts then £8 postage.. seemed a stupid ammount for postage so i passed. http://img145.imageshack.us/img145/9568/rxpl.jpg its item "4" in the list 25mm
