This post is 4430 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I need to replace my relay for my signal indicators. I pulled out the battery and it seems like it is attached to the casing that holds the battery. Based on that I think I need to remover the oil reservior (left side) to get to it but I can't seen to figure out how to remove it? There is one bolt at the top of the reservoir and I removed it but I am not sure what to do next?
Can you help me? Please send advice to [email protected] Put RD400 in the subject line.
I appreciate any help.
Happy Holidays!!
Garry
remove battery holder it is attached to that , much easier than removing the oil tank
Would be 'preciated if you could post an intro in the newbie thread, just so we can get a better picture of what sorta things your into, the bikes you ride, that sorta stuff e.t.c
also, photos would be usefull, im not familiar with your bike but if you post some snaps i could probably offer some advice
