December 12, 201213 yr I have a 2011 ybr 125 and want some heated grips are the handlebars 22mm and does anyone know if there easy to fit
December 12, 201213 yr Hi Mark, Welcome to the YOC, usually best if you do an INTRO before asking "HOW TO" as some folks like to get to know you before they will answer your questions, it's a club so you have to say Hi first, NOT knocking you just saying it's polite to say Hello.
December 12, 201213 yr Moderator As Slice re the intro. Yes and yes, if you know what you are doing. Just some simple wiring.
December 12, 201213 yr Author Hi fellow Yamaha riders and thanks I'm not good with wiring I'm great at dismantling and putting back together but wiring is always a struggle
December 12, 201213 yr Moderator Dependant on the type. The easiest way is to connect them straight to the battery. Red to the +ve and black to the -ve. The disadvantage is that anyone can come along and turn them on when the ignition is off. Next simplest is to wire them to a lighting circuit. This should be done via a relay so check if the grips have a relay included. Disadvantage is that they will only work with the lights on. Last is to a part of the ignition. This needs a relay too but means that they will only work when the ignition is on and are not lights dependant. Disadvantage is that this is a little harder than the first 2 options. There is a link in my signature to take you to the intro section for a "proper" hello if you feel the need. It should help with replies.
