November 29, 201213 yr Whats the best way to clean the inside of textile gloves? Dont exactly think they'll like the washing machine. Theyre spada enforcers and ive checked their website. Theyre about 8 months old and have started to smell abit inside.
November 29, 201213 yr Many people do machine-wash, but it *may* destroy the waterproofing. Could try warm soapy water and a scrubbing brush, then rinse with cold water and hang to dry for about 2 days. What do the instructions that came with them say? Alternatively, phone SPADA up and ask: 01384-413-841
November 29, 201213 yr i would advise against machine washing, all our military issue goretex stuff looses its waterproof properties when washed and im assuming that the spada gloves will use the same sort of technology i would suggest turning them inside out and using a mild detergent (fairy liquid) with warm water to gently scrub the inside and hang them up to dry naturally
November 29, 201213 yr I have a berghaus jacket which gets washed in the machine,thenput it in the tumble dryer on "low " heat which dries it and also re-waterproofs it.that was the instructions that came with it.not sure how the tumble dryer re-proofing bit works but it does,had it for years and never lets water in..
November 29, 201213 yr Author Cheers guys Many people do machine-wash, but it *may* destroy the waterproofing. Could try warm soapy water and a scrubbing brush, then rinse with cold water and hang to dry for about 2 days. What do the instructions that came with them say? Alternatively, phone SPADA up and ask: 01384-413-841 Ill drop them an email now. I dont fancy taking the risk. What about blathering them inside with Febreeze? Aye, was going to try that, but it only covers the smell, not clean them. i would advise against machine washing, all our military issue goretex stuff looses its waterproof properties when washed and im assuming that the spada gloves will use the same sort of technology i would suggest turning them inside out and using a mild detergent (fairy liquid) with warm water to gently scrub the inside and hang them up to dry naturally Cant turn them inside out I have a berghaus jacket which gets washed in the machine,then put it in the tumble dryer on "low " heat which dries it and also re-waterproofs it. that was the instructions that came with it. not sure how the tumble dryer re-proofing bit works but it does, had it for years and never lets water in.. Ill try emailing them first and depending on the reply, try this. Thanks again
November 30, 201213 yr Bi carb of soda, same as for sweaty trainers, and if needs be, Scotchguard or tent spray will waterproof again.
November 30, 201213 yr Lidl do a W5 brand waterproofing spray that works and is a lot cheaper than branded.
