Aerox Not starting PLEASE HELPP !!!!
Hi all, I have recently changed a piston on my yamaha aerox and now it will only start with the choke on and with full throttle but will only rev up to about 2000 rpm but as soon as you release the throttle it dies again, all jets are clear , float is ok, new spark plug, new air filter and a new ht cap. any suggestions please, thanks.
Is your piston in the right way around?
Yes I have got the arrow pointing forwards at the exhaust port, I'm sure that's correct ? But now it will not fire at all and is unregularly backfiring ?
Try clearing the fuel from the exhaust by shutting of the gas,pull the plug and crank it over. Then a new plug and only turn the gas on long enough to fill the carb and see if it will start and run untill out of gas. sounds like dirty carb flooding the motor.possibly float stuck
Piston arrow to exhaust=right
That's a good suggestion thanks alot but I'm quite sure I did a good job of cleaning the 2 surfaces and the old gasket did come off in 1 piece, also there is fuel getting to the cylinder as after a few kicks there is fuel on the plug and I have a good spark it just won't go.
I changed it due to poor compression and then realised the ring had snapped when I took the old piston out, the ring fell off the piston into my hand, and I'm not sure I ordered it from pedparts.com it said it was for any water-cooled aerox so I really do not know what else I can do ?
Take the barrel to a rebore mechanic. They will supply a new piston and re-bore the barrel to match it.
