November 14, 201213 yr Hi all, I have recently changed a piston on my yamaha aerox and now it will only start with the choke on and with full throttle but will only rev up to about 2000 rpm but as soon as you release the throttle it dies again, all jets are clear , float is ok, new spark plug, new air filter and a new ht cap. any suggestions please, thanks.
November 14, 201213 yr Author Yes I have got the arrow pointing forwards at the exhaust port, I'm sure that's correct ? But now it will not fire at all and is unregularly backfiring ?
November 14, 201213 yr Try clearing the fuel from the exhaust by shutting of the gas,pull the plug and crank it over. Then a new plug and only turn the gas on long enough to fill the carb and see if it will start and run untill out of gas. sounds like dirty carb flooding the motor.possibly float stuck Piston arrow to exhaust=right
November 14, 201213 yr Moderator so you've had the barrel off, perhaps you have unfortunately left a torn piece of the original cylinder base gasket trapped under the new one?
November 15, 201213 yr Author That's a good suggestion thanks alot but I'm quite sure I did a good job of cleaning the 2 surfaces and the old gasket did come off in 1 piece, also there is fuel getting to the cylinder as after a few kicks there is fuel on the plug and I have a good spark it just won't go.
November 16, 201213 yr Moderator a few questions... Why did you replace the piston? What size was the old one, What size is the new one? I suggest a compression test can you do one?
November 17, 201213 yr Author I changed it due to poor compression and then realised the ring had snapped when I took the old piston out, the ring fell off the piston into my hand, and I'm not sure I ordered it from pedparts.com it said it was for any water-cooled aerox so I really do not know what else I can do ?
November 17, 201213 yr Moderator But how do you know you bought the right size one? Have you still got the old one?
November 17, 201213 yr Moderator Take the barrel to a rebore mechanic. They will supply a new piston and re-bore the barrel to match it.
