Update;
painter phoned today, he's just finishing off the base paint and ordering the vinyl today.
I picked up the machining job yesterday from MSC (or western rebores) in manchester. top bloke,ex bike racer and checks clearances for you too.
so he puts in a head stud after i snapped mine trying to get it off, swapped over the liners to the ones that match the pistons,honed and skimmed them, then checked all my valves (one was bent)
Took the best valves from the spares motor, then recut the valve head and valves.
Then he skimmed the head all for £200.
love the machine oil smell too
here's the skimmed barrel
and the head work
  • Replies 333
  • Views 56.2k
  • also went out with Tommy to suss out the timings for the ferry at Liverpool
  • found me spark; combination of things 1) couldn't get to fire manually off battery, so took off the caps and the spark was very weak. even though Dyna say it doesn't matter which way the connecti
  • Just done my cam cover in VHT crinkle finish   looks the dogs B
Hmmmmmmmmm bikerporn... :wank4az:
That looks so neat ,,, and expensive :rolleyes:
very nice Drew looking forward to seeing her finished
OK,finally found this thread again.search didn't work
Painter sent some pictures so far and I'm not that convinced on the words yamaha on the side fairing. and I think it needs a racing stripe on the top of the rear cover.
let me know what you think guys
like this
racing strip on the smaller top cover?
not sure on the "yamaha" looks amateur , I think I use "machine" font which looks better. also there's a split in the fairing and the paint isn't flat
he's not got the front fairing or tank done yet
  • 3 weeks later...
taking the rear shock to KAIS suspension tomorrow to get a new spring and a re-valve to my weight. £210 :o
then I should be picking up the paint hopefully next week as I have Thursday and Friday off, shock will take a week so it should tie in nicely.
just done a re-shim and need 2 x 255mm shims which I've ordered from Wemoto
That's a bloody big shim, whats the valve gear on a ship?
Just trying to imagine an engine with valve clearances measured in feet?:wacko:
Admins, kindly delete this post if deemed inappropriate.
Al
Edited by DDT: Thank you, I have.
picking up the paint tomorrow and the rear shock's gonna take another week as they will have to send away for a new spring.
engine completed now and just need to get it in the frame but need the shock and swing arm installed before I can do that.
on the home stretch now :D
Woohoo!! only been 3 years in the making,
Looking forward to the finished piccies :)
Looking forward to seeing its transformation from last years Squires meet up, Drewps. :-)
yeh Drew make sure you put the side stand down properly, imagine how bad you would have felt if you'd had that paint done last year
picked up the paint from Andys bikes in Ilkeston
then I've fitted the front fairing, which is all I can do till the rear shock gets done
looking good, just a bit wary of damaging the paint (which is going to happen, lets face it)
Looking good  mate, Pauls bike couldn't have gone to a better home.Really looking forward to seeing the finished article. :thumb:
cheers Paul, it is turning out really good.
Just hope the engine is done right :unsure:
Really smart Drew I'd take the nosecone back off for now! Too risky.
