I had some 10w already and decided to try it. racing on smooth tarmac is a bit different than these pot holed roads I traverse.
I believe an early r6 shock fits the FZ chassis but may need the spring uprated due to the way the link system works.
  • 2 months later...
  • Replies 333
  • Views 50.5k
  • also went out with Tommy to suss out the timings for the ferry at Liverpool
  • found me spark; combination of things 1) couldn't get to fire manually off battery, so took off the caps and the spark was very weak. even though Dyna say it doesn't matter which way the connecti
  • Just done my cam cover in VHT crinkle finish   looks the dogs B
finally ditched the useless rear mirrors and fitted some cbr600 ones.
had to keep the brackets but at least I can see behind me and they look better IMHO
looks good Drew, you'll be able to see me a bit better now, You should get magnified mirrors so i'm not just a little dot!
bike partially stripped for frame powder coating.
625ef4e7-7021-443c-b7f4-039bae821074_zps
drained the oil as it was warm, will drop the engine and store.
just need to see how I can mod the brand new Hagon shock I got as it was originally for a cbr600. (unless someone wants a swop)
stripped even more of the bike today. just the engine and and little bits to go.
I was mainly messing with the new shock and coming up with a workable length.
Can anyone lend/sell a YPVS dog bone links, i just need them to see what I can achieve with the height. or failing that the actual length of them so i have a starting figure?
look like these
well I've decided not to go the CBR shock route now, too much hassle. It is going to be cheaper to get the original shock rebuilt!
so I've put it on the market to sell.
the bike is totally stripped now and I've noticed the head is weeping slightly, I have a head gasket so might swap the head for the refurbed one I already have and keep the later XJ cams.
I already had tapered head bearings fitted but they were pretty loose, but well greased. I had purchased a set thinking that they were knacked, might still fit them though!
I'm going to visit the powder coaters soon, keeping with the silver for the frame as it ties in the forks and swing arm and just looks right.
Picking up some more plastics friday from a guy off facebook FZ600 page :)
took out the head bearings today and gave the front end a good clean.
the parts list grows (doesn't it always) and gaskets cost a fortune. Ordered a new oil strainer as couldn't get it completely clean!
needing some stainless hoses all round too!
eh? £57 for 8 valve seals!! :eusa_doh:
FFS, I'm gonna order some viton from the USA £18 for 8 and a superior product
took the head off today and it was fairly coked up. cyl #4 was running slightly weak.
when the head was off this greeted me :(
now I have a spare barrel from the FZ engine, but the bores in this still have their honing present
maybe i can get the liners changed over into the fz barrel
thoughts please?
Drewps
Bloody ell drewps. a crack" cylinder 4 lean ? was valve burnt ? is that where the weep was,
not it was #1 that was leaking
not super weak by any stretch just a tweek needed on the carbs. I think that the PO crushed the rubber O ring as it was really hard to pull out and was peened over
decided to trial fit the R6 shock I got, def doable. make an adapter for the top of the shock to clear and hopefully I can use the YVPS dogbones as the original hits the rebound adhuster.
can someone please, if you have a YVPS, measure the swing arm bracket length and inner diameter?
someone did a lovely CNC version
  • 3 weeks later...
You flash harry you " :colors:
looks good Drew, hope its not ready for IOM :tounge:
Wow what a bargain :headbang:
if they work, no big deal if they don't.
hopefully getting the paint off to andy2bikes in derby this week unless I get a better offer/quality on price
switch gear done, shock mounts will be done this week and I'll have the front shocks done as I've got some racetech linear springs to fit in there.
I'm off work now so I'll strip the other engine this week and see what I have cylinder wise
then powder cost frame and then rebuild starts
I think you'll find if your front brake don't work Its a big deal :eusa_think:
