I have just come back from Tesco where I spotted Castrol Power 1 Racing 4T OIL
on offer for £3 a litre! The only problem is the oil is 10w40 and my bike takes
10w30. There was about 30 litres, and as I am going to change my oil regularly
from now on I really could do with buying the lot. Will it make a difference if I use
10w40 instead of 10w30? Please can someone explain it to me.
Hi
I would not worry about using 10w40 oil over 10w30 oil providing it is the correct oil for the task i.e.: motorcycle engine oil.
In fact the 10w40 oil will function over a wider temperature spread, so it should retain its protection/lubrication/cleaning, properties for longer
If you do an internet search for kinematic oil comparisons, you will find some listings for various comparison tables. they will explain it far better than I can,
30 litres at 2 litres a year = 15 years! Worth buying a few though.
10-30 FOR TEMPS FROM-10C TO +35C 10-40 FROM -10C TO +45C SO AS YOU CAN SEE THEY BOTH COVER THE TEMP RANGE YOU RIDE IN .BUT THE 40W IS A HEAVIER OIL AND WILL ROB A VERY SMALL AMOUNT OF HP.
SORRY ABOUT THE CAPS PUTER IS JAMED
The last thing I need is a slower bike, it is as slow as it is
I might just buy 4 litres as I am selling the bike in March,
I have just paid £10 a litre for the same oil (power 1 racing)
and that was cheap. Tesco have reduced it from £12 odd.
I'll buy 4 litres and that will take me up until March, I've
only just changed the oil. If I don't like it when I try it, I'm only
going to be losing out on £6 give or take, so it's worth the risk.
Thanks guys.
Got to be honest i would think clutch drag is a more likely problem than being able to notice any horsepower loss.
If it turns out to be wank, I will just change it and sell the other bottles on eBay.
How did the stiif changes turn out grouch"o ,,, :eusa_think:
LOL funnily enough it seems to have sorted itself out more or less. It's still not 100% but it's
a hell of a lot better.
10w 40 will be fine, the majority of bikes in the uk will be running it.
I think the oil youve got is fully synthetic though, this has been known to cause clutch slippage on some bikes. A semi synth would be more suitable for your bike imo.
Yeah it's fully synthetic, it's to late now to get semi, I've got 1 litre of 10w30 and 4 litres of 10w40 lol, that should last until
I sell the bike in March.
