Posted October 5, 201213 yr I haven't changed the engine oil in my bike since buying it 6 months ago. How often do I need to change it?
October 6, 201213 yr Moderator Don't have it I would think theres a good chance you could download that one for free from the Yamaha website
October 6, 201213 yr Author I never thought of that. It just got me thinking when I have bg oil changed every after ride or every four rides.
October 6, 201213 yr Moderator I never thought of that. It just got me thinking when I have bg oil changed every after ride or every four rides. eh?
October 6, 201213 yr Author Wtf happened there? What I meant to write was..................... It just got me thinking after reading classified ads saying oil changed after every ride, or every four rides.
October 6, 201213 yr It's a racer thing ,lots of us change the oil after a race it's cheaper than changing parts.Its overkill but when your running the bike at 100% of what she's got it's hard on oil. Rule of thumb of road use is every 3000 miles or 3 months,what ever comes first oil breaks down with daily heating and cooling and trap moisture in itself effectively thinning it. same with miles. think of oil as ball bearings that wear down in time.
October 6, 201213 yr Author On that note I better change it. I ride my bike daily and ride it hard as well, so it's long overdue I better start comparing oil types and brands now. I'm not going to put cheap crap in it.
October 6, 201213 yr Grouchy, compare oil in your bike as blood in your body, without it your bike/body will die so take good care of it. Spoil it even. I'm not saying change it every 10 minutes but change it regulary.
October 6, 201213 yr Author I think I will start changing it every months, I've got a magnetic plug as well to put on it, it says it attracts all the microscopic metalic crap and keeps at the bottom near the plug.
October 7, 201213 yr Yep doing often is better,gives you a chance to see whats going on inside the motor without taking it apart. Have a good look at the oil and filter for bits of metal and bronze bushing every time you change the oil if you start to see lots then something is going bad. I use valvoline 10 w30 in cloder temps and 10-40 in hotter temps,the whole bs about not using car oil cause it will make your clutch slip is a old wives tale made up by someone to charge you more for a liter of oil.
October 7, 201213 yr Yep doing often is better,gives you a chance to see whats going on inside the motor without taking it apart. Have a good look at the oil and filter for bits of metal and bronze bushing every time you change the oil if you start to see lots then something is going bad. I use valvoline 10 w30 in cloder temps and 10-40 in hotter temps,the whole bs about not using car oil cause it will make your clutch slip is a old wives tale made up by someone to charge you more for a liter of oil. I think you may have stirred up another hornets nest There are those who would advocate otherwise
October 7, 201213 yr Moderator Never more than twice a year for me. Always use a good quality oil that is meant for bikes and an OEM filter (if you have one). I like Rock oil Guardian semi synthetic. I disagree with dt502001 about car engine oil use. Just my opinion but I would not use it. I also disagree with using different grades for different seasons. Just the way it is.
October 12, 201212 yr Author I have just found out that I have to dismantle my engine to access the filter, also I think my bike has a strainer and not a conventional filter?
October 12, 201212 yr I have just found out that I have to dismantle my engine to access the filter, also I think my bike has a strainer and not a conventional filter? Whaaaaaaaat???? dismantle my engine to access the filter I don't think so. also I think my bike has a strainer and not a conventional filter? is it a bike or a kettle?
October 12, 201212 yr Author I have now established that my bike indeed does not have a conventional oil filter, it is a strainer which I can just remove and clean. http://www.fixya.com/motorcycles/t1778464-oil_filter_yamaha_xt_125
