Posted September 9, 201213 yr hi to all dear member . . i'm a university student from iran. 2 months ago i bought a 1996 DT200WR (3XP) in my country by paying 2000 $. 2 day's ago i changed its candle( or spark plug). today its candle fused in cylender and wrecked piston and create a strip in cylender wall. i changed it piston and polishing the cylender wall.but now ring of piston having bad noise in cylender ( jiggly in cylender.) Now i want to buy a cylender( no piston just cylender). but in our country this part is very expensive. i want to buy from other country. do you now where this part is selling? please help me.i really want your help. thank you very much
September 10, 201212 yr Author i plished the cylinder wall and use another piston. the piston and ring that i used is the yamaha dt LANZA's piston and ring. now when i starting the engine the ring starting to noising. what i do to cutting of the noise.? Hi" why not get oversize piston, & rebore, much less expensive thanks for your offer.if it possible for you explain me for use oversize piston and cylinder? which cylinder and piston i used.? thank you
September 10, 201212 yr Author ooops!.....thank you for giving link but this site is filter in this DAMN country ( iran )
September 10, 201212 yr Moderator see the part numbers..can you use google in Iran? http://www.ytcn.nl/archief/Archief/Yamaha%20Parts%20Manuals%20ALL%201950-1996/WR/WR200RD.PDF
November 2, 201212 yr Author see the part numbers..can you use google in Iran? http://www.ytcn.nl/a.../WR/WR200RD.PDF yeah i can use.. thank you friend for this pdf. do anyone know where i find and buy my motorcycle parts , like piston and ring and etc.????
November 2, 201212 yr i plished the cylinder wall and use another piston. the piston and ring that i used is the yamaha dt LANZA's piston and ring. now when i starting the engine the ring starting to noising. what i do to cutting of the noise.? thanks for your offer.if it possible for you explain me for use oversize piston and cylinder? which cylinder and piston i used.? thank you The DT Lanza is a 230cc engine, you have a DT200R, have I misread something along the way?
November 2, 201212 yr Author The DT Lanza is a 230cc engine, you have a DT200R, have I misread something along the way? yes your right bro, but i take lanza piston from my friend and set it in cylinder and i see work it !! some of repair man said to me that lanza and wr have same engine but lanza is 230 and wr is 200.
November 2, 201212 yr Moderator Here is another parts catalogue http://www.incolmotos-yamaha.com.co/site/LinkClick.aspx?fileticket=C6pOu6aaKrw%3D&tabid=360 I do not understand why they list 4 pistons but only 1 set of piston rings you need to know which piston to order from the choice of 4 and also the correct rings to fit that choice of piston
November 18, 201212 yr Author Here is another parts catalogue http://www.incolmoto...aKrw=&tabid=360 I do not understand why they list 4 pistons but only 1 set of piston rings you need to know which piston to order from the choice of 4 and also the correct rings to fit that choice of piston thank you but dear friends , now, i really want a cylinder block and piston for my bike.. do anyone know where i can buy them? my brother is in toronto,canada. he can buy them for me and send them to me.but he said couldnt find cylinder and piston for my 1992 dt200wr in their city. do you know how he can buy them??.i dont find anything in the internet.
November 18, 201212 yr Fazl, you need to get your brother in Toronto, to contact his local Yamaha dealer. For a 1992 DT200WR I get the model as being a 3XP3 the part number for the cylinder is 3XP-11311-00-00, as Airhead says there are 4 part codes for the pistons but they are all stating as being the standard size pistons, 3XP-11631-01-A0, 3XP-11631-01-B0, 3XP-11631-01-C0, 3XP-11631-01-D0, Piston Rings are 3XP-11610-00-00, Small end Bearing is 93310-316C9-00, Cylinder base Gasket is 3XP-11351-00-00, Cylinder Head Gasket is 3XP-11181-00-00. Also there might be a small chance you can buy the Cylinder/Barrell from Ebay, a couple of lads in another forum I use that have the DT200's often buy second hand parts for their bikes on there. Hope that helps you.
November 18, 201212 yr Author Fazl, you need to get your brother in Toronto, to contact his local Yamaha dealer. For a 1992 DT200WR I get the model as being a 3XP3 the part number for the cylinder is 3XP-11311-00-00, as Airhead says there are 4 part codes for the pistons but they are all stating as being the standard size pistons, 3XP-11631-01-A0, 3XP-11631-01-B0, 3XP-11631-01-C0, 3XP-11631-01-D0, Piston Rings are 3XP-11610-00-00, Small end Bearing is 93310-316C9-00, Cylinder base Gasket is 3XP-11351-00-00, Cylinder Head Gasket is 3XP-11181-00-00. Also there might be a small chance you can buy the Cylinder/Barrell from Ebay, a couple of lads in another forum I use that have the DT200's often buy second hand parts for their bikes on there. Hope that helps you. thank you so much NEV. i said your words to my brother, and now im waiting for his answer. best regards.
December 9, 201212 yr Author finally i bought a (yamaha fabric) new cylinder and piston ring with 500 $ and set it to my moto, NOW IT WORK !
December 9, 201212 yr $500 bucks,,,, is that US dollarrs , i would need a repacement engine for that,,,,
