August 23, 201213 yr im having troulbe getting the engine to fire i have replaced the points and condencer tried changing the coil it fired up and then shut back off nothing after that
August 23, 201213 yr Moderator Hi night. Welcome to the forum. Assuming what you have changed are set up ok. Have you Fresh fuel Changed the spark plug Cleaned the carb Checked for compression Please take the time to say "hi" in the newbies section.
