I have a 1972 Yamaha 360 RT-2 that i got from my uncle. When i was under it draining the old oil out of of it there were two bolts. One was the main oil drain and the other was under the transmission and they both had oil in them that drained out. The bolt under the transmission was hollow and had a spring and bearing of some sort in it. When I was putting both bolts in the oil drain tightened and the one under the transmission broke. I have to relapse it but there is nothing in the manual about that bolt. Do I have to make a new one or are there replacements out there? And what does it do???
