Just got a Yamaha DT 125 R t reg two weeks ago and its giving me hassle already i think it may be a fuel issue or perhaps dirt in my carburetor but as a mechanical novice i have no idea what to do any ideas?
Liam Wallace
A good starting point.
Ah thank you i apologies for barging on like a child demanding assistance thank you ill search through the forums to see if there are any that may help me resolve my problem. I'm Liam by the Way so hello all other bike lovers hope you're all well.
Start a thread in the workshop section that can be found on the front page about two thirds down the page.
You will need to explain what the symptoms are;
Does it start?
Does it run?
Does it tick over?
Have you ever had it running?
Is there fuel in it and is it fresh?
Does it kick over?
Do you get lights when you turn on the ignition?
That kind of stuff.
The better you explain what the issues is, the easier it is to help. In the workshop area.
Thank you for the info i'll do that. Have a pleasant evening.
