Help needed from Pre divi xj600 owner
Exjay
This post is 4303 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Am rebuilding a pre divi XJ600. Not got the engine running yet, I am sorting out the loom and the electrics.
  • What I need to know is should the oil light come on when you first switch the ignition on? or is it only when the oil level falls?
  • I do not want to remove and check too much stuff if it is working correctly.
  • Apart from the neutral light, is there any indication that the ignition is switched on?
  • Phil
mines only comes on as i turn the engine over as soon as its running it goes off.
only light is the nuetral light like you say to display ignition is on.
