Posted July 17, 201213 yr we are restoring our rd400.. will the fork stantions fit from a lc?.. we want to put twin discs on the front....
July 17, 201213 yr Moderator good project, I think Merv will be back on here and extiling the virtures and vices of the aircooled rd club of which I frequent. You would get a lot more advice from there. not sure of the model you have, but the brakes are the same as the xs range from 250 to 1100. If you have a bracket on the left hand fork stantion you could use SR500 brakes which are left handed. The wheels normally come pre-drilled to take another disk. even better, I think the aprillia rs125 fits and has stonking brakes on them (they fit the xs400 frames of which the rd uses the same headstock bearings)
July 17, 201213 yr Author good project, I think Merv will be back on here and extiling the virtures and vices of the aircooled rd club of which I frequent. You would get a lot more advice from there. not sure of the model you have, but the brakes are the same as the xs range from 250 to 1100. If you have a bracket on the left hand fork stantion you could use SR500 brakes which are left handed. The wheels normally come pre-drilled to take another disk. even better, I think the aprillia rs125 fits and has stonking brakes on them (they fit the xs400 frames of which the rd uses the same headstock bearings) its an rd400 E, 1980-81
July 17, 201213 yr Moderator all the RD experts are on http://www.aircooledrdclub.org.uk/forum/default.asp lc stanchions are only 32 mm i believe that will be 35mm , look at XS 650 or summat like that where are yuo in Cornwall then ?
July 17, 201213 yr Author all the RD experts are on http://www.aircooled...rum/default.asp lc stanchions are only 32 mm i believe that will be 35mm , look at XS 650 or summat like that where are yuo in Cornwall then ? menheniot..... thanks for that..
