Posted July 3, 201213 yr Hello Again Does anyone know if a rear paddock stand will work with a Yamaha WR125X Supermoto?
July 3, 201213 yr Author cannot not fit bobbins to swing arm as there is no where to mount them. The paddock stand I was thinking of purchasing has universal cup fittings.
July 3, 201213 yr Moderator I wouldn't use cup fittings. The bike can slide along and off them. My preferred option would be to use an Abba stand and a universal swingarm removal kit - but it is a lot of cash. Another alternative is to look for a lift like this LINKY I got mine from evilbay from a local guy for about £20.
July 3, 201213 yr Just get one of the motorcross stands http://www.racespec.co.uk/acatalog/Lift_Up_Stands.html cheap and will work for the bike you have.
July 3, 201213 yr Moderator Those are fine providing they go under the bike when the bike is on the floor. My experience is that you need to lift the bike onto them before you use the lift. All about ground clearance.
July 3, 201213 yr http://www.dirtbikexpress.co.uk/bike_stands/drc_bike_stands/drc_hc2_lift_bike_stand_with_damper This ones hydraulic, i used to use one on my old 650. Brilliant pieces of kit. Just slide it underneith and jack it up.
July 24, 201213 yr I just got a rear stand with the cups for my XJ6. £20 from ebay brand new. Does the job perfect!
