June 29, 201214 yr hi all im on rebuilding the engine a 1985 xt 600 cc and ive came across a bit of a stumbling block. its a 550 cc lump in a 600 frame and before i realized this i bought a gasket kit for a 600 cc :eusa_doh:the cylinder head and base gaskets will be no good but my question is will the rest of the set fit ? looking on Google images the 550 and 600 engines took identical and so im hoping that the only difference is the bore
June 29, 201214 yr Hi Mark , cant be positive but the i think most of the gaskets will fit, you may find the odd o ring thats different but most of the set should be OK. Good luck with the build. TTB
June 29, 201214 yr Author thanks very much that's gave me peace of mind my cylinder needs a re-bore so will i need a custom cylinder head gasket for it?
June 29, 201214 yr Moderator my cylinder needs a re-bore so will i need a custom cylinder head gasket for it? No.
