June 19, 201213 yr hi i have a midnite star 1300 and i want a smaller reg plate as the one thats on it is standard uk size is there a legal small plate u can get or am i stuck with the one thats fitted any help please.
June 20, 201213 yr Moderator Basically as long as the letters/numbers are the correct size and spacing and you have a minimum of 11m border around them that is all i can see is required http://www.direct.gov.uk/en/Motoring/PersonalisedRegAndNumberPlates/DG_181503 Motorcycles and tricycles Motorcycles registered from 1 September 2001 must only display a number plate at the rear of the vehicle. Motorcycles registered before 1 September 2001 can display a number plate at the front, but do not have to. The number plate must be a 'two-line' number plate. Motorcycle number plates should have a:character height - 64 millimetrescharacter width - 44 millimetres (except the figure 1 or letter I)character stroke - 10 millimetresspace between characters - 10 millimetresspace between groups - 30 millimetrestop, bottom and side margins - 11 millimetres (minimum)vertical space between groups - 13 millimetres Tricycles made from motorcycles must meet the number plate requirements for motorcycles. Tricycles made from four-wheeled vehicles, such as saloon cars and quad bikes must meet the same number plate requirements as all other vehicles.
