All has been well for the past few weeks, and I was thinking last night it was time to sell the car. This morning it started first kick, but lost power after a few minutes, then I couldn't start it.
I just went out and started it, (on film) and it cut out in neutral. - see link
Not sure what to think, it wasn't sounding that great in idle either. Any help is very welcome.
http://www.flickr.co...t84/7163501369/
ok, ran it with tap off. ran for about 5 seconds and then cut out as expected. should I try it again with tap open? its got about 1/2 a tank of gas.
well then
you will find that your carb is over filling check the float height setting
check the float needle is free to move
maybe before any of this, give the carb a tap with something like the wooden stock of a hammer just in case it jolts something free
Thanks, will look at the carb when the rain stops. It ticks over quite well in idle but every now and again the drops a big chunk of revs, then picks back up, but doesn't seem to have the same sound as usual, bit more spluttery. when I rev its not really getting the power, then sputters a bit more and loses it all together. want to use the word 'misfiring' but I know thats a technical term, but thats how it feels, like its misfiring. Cleaned and checked the carb a few weeks ago and its been super fine since then.
just checked the spark plug, its black, wet and oily. the plug was new 4 weeks ago. think this will cause the misfire i've been getting.
fit another and start the bike, switch the fuel off and rev the engine freely to clear the flooded crankcases...when it dies switch on the fuel, then off again and re-start the engine and repeat another couple of times
ok, changes the plug, and followed steps above, it seems to be working fine. Think the new plug shows the problem was the misfiring.
But what has caused this problem should I be worried?
