April 16, 200520 yr Right. I've got a spare (lightened) flywheel that I want to stick on my '01 DT and the puller I've got (350 YPVS) doesn't fit . I (stupidly) assumed that it would, being another Yam and all, but no. Does anyone know of a suitable puller (M&P?) that'll work on my DT? Or a cunning trick that'll work (I dunno, something involving levers and pulleys, I'd imagine). Or am I going to have to bite the bullet and stump up for a genuine Yamahahahahaha part? Cheers, Mick.
April 16, 200520 yr Right. I've got a spare (lightened) flywheel that I want to stick on my '01 DT and the puller I've got (350 YPVS) doesn't fit . I (stupidly) assumed that it would, being another Yam and all, but no. Does anyone know of a suitable puller (M&P?) that'll work on my DT? Or a cunning trick that'll work (I dunno, something involving levers and pulleys, I'd imagine). Or am I going to have to bite the bullet and stump up for a genuine Yamahahahahaha part? Cheers, Mick. ← The M&P ones fit fine. There are also a few on Ebay at the moment.
April 16, 200520 yr Author Don, Sorry to be a pain in the arse- but which one? I did a search and came up with 3 or 4 different ones. The MX puller is the same as a 350 YPVS I think (27 x 1, LH thread) and the generic 'fits most Jap bikes up to 175cc' looks to have a large threaded section which won't work on my flywheel as there's no thread to screw into. What does the 'proper' puller look like? Cheers, Mick.
April 16, 200520 yr Don, Sorry to be a pain in the arse- but which one? I did a search and came up with 3 or 4 different ones. The MX puller is the same as a 350 YPVS I think (27 x 1, LH thread) and the generic 'fits most Jap bikes up to 175cc' looks to have a large threaded section which won't work on my flywheel as there's no thread to screw into. What does the 'proper' puller look like? Cheers, Mick. ← The one I have here is marked as M27P1L and came from M&P. It fits both my DT125R's and my TDR 250's.
April 17, 200520 yr Author Cheers for that Don. It looks the same as the RD350 YPVS puller I've got. What years are your DTs? There's no threaded section on either of my flywheels for a puller to screw into
April 17, 200520 yr Cheers for that Don. It looks the same as the RD350 YPVS puller I've got. What years are your DTs? There's no threaded section on either of my flywheels for a puller to screw into ← I have used that puller on a 1990, 1991, 1993, 1996 and 1999 DT125R's. You sure that the flywheel is from a DT125R ? Maybe the models after 1999 have a different flywheel. This is the only DT125R flywheel I have now.
April 17, 200520 yr Author Maybe the models after 1999 have a different flywheel. This is the only DT125R flywheel I have now. ← It was all change from 2000-on. My flywheels are different to that one. The rivets are further from the centre and there are 6 holes the same distance from the centre as the rivets. Oh well, looks like I'll have to get one from a Yam dealer £££££££££££££££££££ Cheers for your help, Mick.
January 20, 201214 yr mick wot tool did u get after i have a 2006 dt x an it sounds like ur flywheel m8 searching ebay an cant see witch one i need any help will do m8 ?
January 20, 201214 yr Moderator mick wot tool did u get after i have a 2006 dt x an it sounds like ur flywheel m8 searching ebay an cant see witch one i need any help will do m8 ? Give yambits a call dude
