June 3, 201214 yr Moderator I fitted one of these to my DT, might come in handy for help with jetting, it has a thermocouple attached to a copper ring to go between the spark plug and cyl head. It's very responsive and cheap to buy http://trailtech.net...emperature.html [media=]
June 4, 201214 yr Author Moderator @ DirtyDT, easy going temps around 160/180C, hard work temps I have seen up to 220C...all this means nothing to me but i'm learning mate @Drewpy, Had it quite a while now, around £30 ish, you have to buy one suitable for your particular size plug
June 5, 201214 yr Moderator @ DirtyDT, easy going temps around 160/180C, hard work temps I have seen up to 220C...all this means nothing to me but i'm learning mate Hot enough to cook sausages at a rally then!
June 9, 201214 yr Moderator Looks like the kind of thing that would be good on a twin, temps matched she must be sweet. Multiple sensors on one display?
June 9, 201214 yr Author Moderator Looks like the kind of thing that would be good on a twin, temps matched she must be sweet. Multiple sensors on one display? sadly no Jason but with another sensor bought seperately and a switch...hell yeah!
June 9, 201214 yr I wonder does it read the heat of the engine or the heat the plug gets to,,,,,,,,, probably the same tem anyway but i always thaught the plug would be ever-so-slightly hotter. Suppose it doesnt matter anyway Looks good on the bike too.
