my dtr sm came with a standard exhaust and dep end can,i had a dep exhaust fitted and ever since my jacket and if carrying a rucksack smell badly of oil after a ride out wether it be for 5 mins or an hour.does anyone else have this problem with the full dep system fitted?
what's the problem?
best smell around :)
not when your clothes are stinking of it its not
Par for the course un fortunately.
will a different end can sort the problem?
Holy sheit! That's for real?! :D I figured now that I'm going to work smelling of exhaust I'll save a ton of money not buying perfume. :)
Its a 2 stroke, its pretty unavoidable im afraid.
why did i not have this problem with the standard exhaust fitted.i did not have the problem with the cagiva mito,thats prob because the end can is lower down on the bike
is the rubber joint between the exhaust and silencer leaking?
i cannot remember if there was one when the standard exhaust was on the bike but there was not when the bike shop fitted the dep exhaust.i noticed that once the dep exhaust was fitted that oil was leaking from where it joined the end can has it did not marrie up correctly,i has to put some gum gum round it and then a piece of rubber tubing held in place with two jubilee clips
thats your problem then, get a rubber joint fitted, easily bought from fleabay :thumb:
i would imagine this would work has i have it now?
You want to try the TDR, 2 pipes high up you stink to high heaven. You can tell which is the truck i usually use at work from the 'aroma' of burnt 2 stroke. My rucksac is probably watertight now :crazy:
Your old pipe probably had a smaller outlet pointing down which means the worst of the fumes will get caught in the air under the bike maybe, but that costs HP.
..........................ever since my jacket and if carrying a rucksack smell badly of oil after a ride.....................................
I wish people wouldn't post porn on the forum.
is there a specific rubber joint for the dtr
It may be its because the dep doesnt have a spout so the fumes arnt being directed whereas the standard one does and the one on your mito most likely did to.
My bike gear always smelt of 2 stroke, i eventually got used to it.
my standard exhaust on the dtr sm does not have a spout ryan just a straight pipe the same has the dep,i think you could be refering to none sm dtr's
Im pretty sure the standard dtx and dt re have spouts on the cans.Google it.
