clothes smell of oil
This post is 4580 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
my dtr sm came with a standard exhaust and dep end can,i had a dep exhaust fitted and ever since my jacket and if carrying a rucksack smell badly of oil after a ride out wether it be for 5 mins or an hour.does anyone else have this problem with the full dep system fitted?
Link to comment
Share on other sites
Par for the course un fortunately.
Link to comment
Link to comment
Holy sheit! That's for real?! :D I figured now that I'm going to work smelling of exhaust I'll save a ton of money not buying perfume. :)
Link to comment
Its a 2 stroke, its pretty unavoidable im afraid.
Link to comment
why did i not have this problem with the standard exhaust fitted.i did not have the problem with the cagiva mito,thats prob because the end can is lower down on the bike
Link to comment
is the rubber joint between the exhaust and silencer leaking?
i cannot remember if there was one when the standard exhaust was on the bike but there was not when the bike shop fitted the dep exhaust.i noticed that once the dep exhaust was fitted that oil was leaking from where it joined the end can has it did not marrie up correctly,i has to put some gum gum round it and then a piece of rubber tubing held in place with two jubilee clips
Link to comment
You want to try the TDR, 2 pipes high up you stink to high heaven. You can tell which is the truck i usually use at work from the 'aroma' of burnt 2 stroke. My rucksac is probably watertight now :crazy:
Your old pipe probably had a smaller outlet pointing down which means the worst of the fumes will get caught in the air under the bike maybe, but that costs HP.
Link to comment
..........................ever since my jacket and if carrying a rucksack smell badly of oil after a ride.....................................
I wish people wouldn't post porn on the forum.
Link to comment
It may be its because the dep doesnt have a spout so the fumes arnt being directed whereas the standard one does and the one on your mito most likely did to.
My bike gear always smelt of 2 stroke, i eventually got used to it.
Link to comment
my standard exhaust on the dtr sm does not have a spout ryan just a straight pipe the same has the dep,i think you could be refering to none sm dtr's
Link to comment
Im pretty sure the standard dtx and dt re have spouts on the cans.Google it.
Link to comment
  • Recently Browsing
