May 8, 201214 yr Decided to overhaul my carb today. wish i hadnt After removing the air box rubbers, the intake rubbers split as i removed them.. can you get um??? i cant find any for love nor money.. the only lead i have they are £100. I think i may go down the ali welding route and get some pipe welded on the collars and use silicone hose to join them up!!!!! to try to fix it , if it aint fixed dave
May 8, 201214 yr Moderator http://www.cmsnl.com/yamaha-xt350t-dual-purpose-1987_model9314/joint_30x1445401/
May 8, 201214 yr Author http://www.cmsnl.com...int_30x1445401/ Almost Its the ones that attach to the cylinder head they are not on the schematic
May 8, 201214 yr Moderator Number 1 & 2?? http://www.cmsnl.com/yamaha-xt350t-dual-purpose-1987_model9314/partslist/B-02.html#results http://www.powersportsplus.com/parts/search/Yamaha/Motorcycle/1987/XT350T/AIR+FILTER/parts.html
May 8, 201214 yr Moderator The second one is 90 dollars so about £65 + postage and hope you dont get caught by the import duty.
May 8, 201214 yr I used araldite on my XT600 and it holds up OK so far, i did use the industrial slow setting one. Applied and lightly pressed together in a vice for a day or so. Simples TTB
May 8, 201214 yr Author think im gonna get them welded... im not paying that much for something so minor
