Posted May 2, 201213 yr Hi, just wondering my Dt first reg April 1980 has a rectangular section swing arm, im sure these had a tubular section arm, If this has been changed for the more modern design will I find that other bits have been changed to make it fit, ie the shock (Mainly curious but may be helpful if I need to overhaul the shock) cheers
May 2, 201213 yr Moderator I doubt it isnt the original one Different swing arm different shock absorber different chainguard what side is the oil tank on? what is the vin number?
May 2, 201213 yr Author Yeah oil tank on the left. Swing arm dosent look 30 years old, in fact its in better nick than the one on my 1999 GSXR
May 2, 201213 yr Moderator you sure the oil tank is on the left i dont see it? 1980 should be on right shouldnt it?
May 2, 201213 yr Author Oil tank is missing, but there is space for one V5 states first reg April 1980
May 3, 201213 yr THE 1979 DT125MX I had defineately had a rectagular swinging arm and from what I remember as Airhead say's the oil tank was on the right hand side and the airbox on the left.
May 3, 201213 yr Moderator If its got the lh filter then it shouldn't have the round swinger. Maybe its an upgrade. Or the fellow doing the part rebuild fitted it. Who knows. Wack the first part of the chassis number (leave the last 3 digits off for safety's sake) up and we will know for certain.
May 3, 201213 yr Author Frame number 2k40018*** So if its original 1980 with the air box on the right and oil tank on the left then the rectangular swing is correct ???
May 3, 201213 yr Moderator you had me confused saying its a 1980 bike, these did have the square sect swing arms as i thought..its a 1979 model thats why the oil tank is on the left...someone fitted a later arm
May 3, 201213 yr Moderator Don't mean to spoil your fun but that 125 is a 175. If it was a 125 the chassis number would start 2A8. 2K4-001 is the earliest of the 175 MX generation dating from feb 78 to very early 79 when the 2K4-010 took over. It was the 2K4-020 that had the square swinger, LH airbox and 6 wire cdi
May 3, 201213 yr Author Thanks guys so..... its a 1979 chassis 175 MX registered in 1980 with a 125 cc 1981 bottom end with a 175 cc Head with a later rectangular section swing arm fitted I guess ordering parts could be interesting. Is it likely that the shock was changed with the swing arm then or would it fit both styles.
May 3, 201213 yr Author No I contacted Yamaha, the engine is 2A815**** and got the following reply: Thank you for your e-mail. The engine number you have providedrelates to a 1981 model year Yamaha DT125 which was produced early in that year. When ordering parts we would recommendthat you quote the Model Code 4J3 along with the Engine Number.
May 3, 201213 yr Moderator the shock will have been changed too unless the width of the original shock bottom pivot was reduced to suit the new arm
May 3, 201213 yr Author Seriously - A massive Thanks to you all would have taken me ages and countles frustrations im sure to get all that figured out
