Posted April 28, 201212 yr I need to find the OEM parts no.s for the needle jet and jet needle for my XS250, Anyone any ideas where I might find them? 'Cos I bloody well can't!!!!...Piggin' Tit'ernet!!!! Some guy in "The Good 'Ole US of A" reckons he may have some but needs the OEM no.s to confirm......
April 28, 201212 yr 'Cos I bloody well can't!!!!...Piggin' Tit'ernet!!!! Weeeeeeeeeeuuuuuuuuuuuurrrrrrrrrrdddddddddd!!!!!!!!!!!
April 28, 201212 yr Author Yep, Cheers Merv, tried all them, parts not listed.....Thanks for the reply tho'. What's so "weeeeeuuuuurrrrrddddddd"?????...Mike..
April 29, 201212 yr Author All Hail Drewpy the Saviour . Go on then Drewp's pray tell what does your book of all things Yamaha say...
April 29, 201212 yr What's so "weeeeeuuuuurrrrrddddddd"?????...Mike.. One does apologize after ones had approx six pints of fosters. No offence intended. Most of my postings are at the weekends, need I say more?
April 29, 201212 yr Moderator parts # needle (4Z1-4) 1M0-14116-02 needle jet 341-14941-90 (X-8) called a mains nozzle you can get those from Allens performance or already mentioned here too
April 29, 201212 yr Author Do you know whats bloody weird Drewp's, I've e-mailed Motocarb and they say no go and spoke to a chap on the phone yesterday at Allen's and he said no joy as well.....Ah,well now I have the parts no.s will try 'em again see if something turns up....Cheers mate...
May 10, 201212 yr Author Ah,Well.....looks like these parts are as common as the proverbial "Rocking Horse Poop/Hens Teeth/Virgins in Doncaster"....Just got some carbs off of Evilbay £17 delivered......... Another question for you Drewp's........What sort of oil pressure should I be getting from the XS??? Doing away with idiot light and fitting a gauge, just want to know what pressure range I will need, Haynes manual don't say....
May 10, 201212 yr Moderator my oil pressure gauge goes up to 100 psi. its 70 psi cold and once dropped to 5 on the toy run ( it started to overheat due to standing traffic and started getting vapour lock) normally ticks over at 10 - 20 psi
May 12, 201212 yr Author Cheers,Drewp's....You are indeed a vast well of knowledge of all things XS......
May 12, 201212 yr Author The carbs I got off Evilbay turned up today..."Good Condition" was the description....PAH!!!! If they in good condition then the ones on my XS are Goddam Brand New!!!!! Anyhow's managed to get one stripped and the internals look fine, even the diaphragms are in good nick...RESULT.. Can't wait to get the little 250 up and running and ont' road.....
