This post is 4615 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
so, this morning - put my leathers on, and my waterproofs - due to normal sunny aberdeen weather - looked like there was a waterfall outside my window !, and unpadlocked my bike - key in the ignition, choke on and press the starter! . . .click. . . .click . . . . seems the water must have got into my starter ??solenoind?? / ??relay??
pushed her down the road abit and booft - she fired up nicely.
Bikes been under shelter at work all day and im just finishing - so i hope its dried out cos i cant be bothered bump starting it again :(
Good luck. Do you cover the bike at night? I think it makes a difference.
Most probably a bad battery or starter motor connection.
Could also be caused by a low battery.
check earth too
I did, untill someone nicked my cover ! waiting till the end of the month to buy a new hevie one, that will hopefully have holes in the bottom so that i can lock it to the bike, or lock it round
check earth too
battery was full, i think it was ether a duff connection or a short due to the horrendus rain -
had to bump her yesterday :(
but started up fine today in the lovely sunshine :D
