Gilera 4V project
Its finally arrived, I can't put it off any longer.
I have finally made a start on the little Gilera :)
here's what I found with the frame
Oops its broken
what's that smeggy thing on there?
cut that thing off and read up on slugging the frame off the chopper underground
I lost my lathe virginity today, and it was great. There is something cathartic about cutting bar on a lathe. It was a bit daunting at first, as it had a plethora of knobs and levers but I soon picked it up. Apparently all the kids just put a programme in and watch their steel take shape. I did it the old school way :D
well my new slug fits great and just needs welding up with the engine in situ to make sure everything fits.
those plates are next and I need some 5mm plate to remake the main stand rests.
  • Replies 286
  • Views 52k
"Gilera 4V project"
There is no way that you will get a V4 in that frame Drewps.
aye, I welded my all of my tracker with an oil cooled arc welder I bought from machine and mart in '82
"Gilera 4V project"
that's why its called 4v
V = vitesse = gears
although if I was called Allen Millyard, it may have happened
  • 3 months later...
little update as I am collecting bits and have most of the engine stuff together.
took a chance on ebay Italy and bought some new after market forks called "Forcella"
any way they came today and they FIT! :hyper:
just need the alloy stuff vapour blasted and can make a start on the engine. at this rate I should be done by Easter next year!
with the repair to the frame you need to V both of the edges of the tube so you can weld it all the way round. to allow good penetration and a proper join,
and then grind back flush for a seamless almost invisible repair.
thanks Beef, Its welded now, just needs tidying up!
done a bit more today, seeing as the Trackers battery has yet again let me down :shakeno:
I 2k cleared the tank and panels after a couple of decals have been applied
I am after a tls drum brake for the front, the original is made of steel FFS :crazy:
tank looks great.
and i have the same issue with my flat tracker killing batteries... but i got a kick start to save me...
I got kick only, the battery was down to 10v, no good for TCI.
just ordered a Ballistic battery from the states as it will be small enough to fit in the tail section with a bit of modding
got a seat today and trialled it on the bike for proportions
bit of a gap at the front, need to ponder that a bit
WOW Drewps. This looks great already.
I haven't seen an old skool Gilera in the flesh for a very long time.
thanks, I plan to have it ready early next year.
its a case of buying stuff as it comes up for sale
  • 3 weeks later...
took the Gilera cases etc to J Percival's in Stockport last week to get the cases Vapour blasted.
Always come out great and can't wait to get the other bits together to start the rebuild :)
common problem of chain letting go, lack of maintenance
trying out new down draft position for carb...not, just put manifold wrong way round ;)
Quality mate! 12 months to get it built.
cheers, just need to save for a con rod kit and other little bits and It'll be done in a weekend
