Forum bug: flags images missing
Only Alex can sort this, I would guess. There were issues when the forum was upgraded a while ago. Info was lost. The images would be in a separate folder and then the forum code would reference these using an image tag (img). If the image isn't where it is expected to be then you normally see a box with a red cross in it.
Thanks, DirtyDT. :)
(I'm a web designer/coder :D)
No need to apologise, you couldn't have known. :)
They probably are or you wouldn't have to guess. :(
Did you hear about the psychic who had a crystal ball?
He could see himself coming.
I intended to go to a psychic fayre once but when I got there a sign on the door said......
"Closed due to unforeseen circumstances"!
The old ones are the best.
Yeah sorry guys I know about this. I just haven't got around to finding the images and re-uploading them. It's just low on the priority list until I finally get to the bottom of the spamming issue. Thanks for pointing it out though.
Fixed :hyper:
Hmm almost. Looks like I need to find the a new set of flags with the right file names otherwise I'm going to have to change all 250 odd manually.
Right looks like I'm going to have to manually rename them all, as I can't find the same plugin anymore. All the new ones have different image names. Let me know if yours isn't working and I'll start changing them that way
Ok I've fixed this properly, but it means that you'll all need to update your profiles. Go to your profile, select the edit profile link in the top right hand corner and reselect your country.
