Moderator DirtyDT Posted March 13, 2012 Moderator Posted March 13, 2012 Only Alex can sort this, I would guess. There were issues when the forum was upgraded a while ago. Info was lost. The images would be in a separate folder and then the forum code would reference these using an image tag (img). If the image isn't where it is expected to be then you normally see a box with a red cross in it.
ddlooping Posted March 13, 2012 Author Posted March 13, 2012 Thanks, DirtyDT. (I'm a web designer/coder )
Moderator DirtyDT Posted March 13, 2012 Moderator Posted March 13, 2012 Thanks, DirtyDT. (I'm a web designer/coder ) Oops. Sorry
ddlooping Posted March 13, 2012 Author Posted March 13, 2012 No need to apologise, you couldn't have known.
Moderator DirtyDT Posted March 13, 2012 Moderator Posted March 13, 2012 I guess my days of being a psychic are over.
ddlooping Posted March 13, 2012 Author Posted March 13, 2012 They probably are or you wouldn't have to guess.
Moderator Airhead Posted March 13, 2012 Moderator Posted March 13, 2012 I guess my days of being a psychic are over. They probably are or you wouldn't have to guess.
mike1949 Posted March 15, 2012 Posted March 15, 2012 Did you hear about the psychic who had a crystal ball? He could see himself coming.
Moderator DirtyDT Posted March 15, 2012 Moderator Posted March 15, 2012 I intended to go to a psychic fayre once but when I got there a sign on the door said...... "Closed due to unforeseen circumstances"! The old ones are the best.
Admin Alex Posted March 30, 2012 Admin Posted March 30, 2012 Yeah sorry guys I know about this. I just haven't got around to finding the images and re-uploading them. It's just low on the priority list until I finally get to the bottom of the spamming issue. Thanks for pointing it out though.
Admin Alex Posted March 30, 2012 Admin Posted March 30, 2012 Hmm almost. Looks like I need to find the a new set of flags with the right file names otherwise I'm going to have to change all 250 odd manually.
Admin Alex Posted March 30, 2012 Admin Posted March 30, 2012 Right looks like I'm going to have to manually rename them all, as I can't find the same plugin anymore. All the new ones have different image names. Let me know if yours isn't working and I'll start changing them that way
Admin Alex Posted March 30, 2012 Admin Posted March 30, 2012 Ok I've fixed this properly, but it means that you'll all need to update your profiles. Go to your profile, select the edit profile link in the top right hand corner and reselect your country.
