This post is 4676 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi all.i have fitted raised handle bars on my sr250 and now the brake cable is to tight a fit.i can only find standard size cables for it in the uk.is there another model with same but longer cable i could order?
Seem to remember the early SR250 had fairly high bars as standard anyway or has yours got low bars on it. Can you post a picture?
it had straight bars on when i got it.and the guy said that the cables were orginal.hpoe these photos come out as im still trying to get the DSCF3094.jpg
Posted (edited)
lets have a photo of the cable to brake drum fixing and adjustment, i'm wondering if a DT175MX cable would do it...readily available and cheap.
Edited by mervin
add picture
Posted (edited)
Edited by mervin
add picture
Weird cos i used the same address each time and is has worked just fine
DT175MX cable
Total length to end of nipples = 132cm
Sheath length to end of adjustment thread = 119.5cm
adjustment thread 8mm
Patterns easily available from ebay, yambits, wemoto etc
  • picture not there mate, copy the bottom box not the one with http at the front
i did copy the bottom one.anyway thanks for the dt175 cable idea.that lenght will do.thanks everyone for the help.
Ur cable is at full adjustment just slacken it y0
Yes and next you will be telling him to use a bit of baler cord instead of a cable i know you old Devon Farm types Jack
